Article ID : 00191974 / Last Modified : 16/01/2026Print
How to set the Clock Radio time and date
My Clock Radio’s time information was reset.
    Follow these steps to set the clock date and time.
    1. Press and hold ENTER/TIME SET for more than 2 seconds. You will hear a beep and the last two digits of the year will start to flash on the display.
      ICFC1
    2. Press + or – repeatedly to select the year, and then press ENTER/TIME SET. Repeat step 2 to set the month, day and time. After setting the time, two short beeps will sound and the seconds will start incrementing from zero.
    NOTE: If you do not press any button for about 1minute while setting the clock, clock setting mode will be canceled.
    IMPORTANT: The current date, time and alarm information will be erased if you disconnect the AC plug from the wall outlet while replacing the battery (CR2032). Please connect your Clock Radio AC power code to a wall outlet when you replace the battery.
