Article ID : 00109892 / Last Modified : 02/03/2015Print
    General information related to charging the Walkman
    You can find below a couple of key points related to the use and charge of your WALKMAN's battery:
    • Before the first use of the WALKMAN, it is required to fully charge the battery
    • Charging must be done by connecting the WALKMAN to a running computer (via USB)
    • The charging time takes up to 4 hours, until the battery indicator displays “FULL”
    • When the battery is completely discharged, it may take up to 5 minutes before the device reacts normally after being connected to the running computer - this is the normal operation of the device
    • The WALKMAN cannot be operated while charging with a computer
    • The WALKMAN should be connected to the computer after the computer is turned on
