Article ID : 00300604 / Last Modified : 29/05/2024Print
What is purpose and function of the Depth Map Assist Continuous AF (AF-D) mode?
    AF-D allows the camera to track the focus of a subject on a wider area. In addition to the 19 AF areas used with the Continuous AF (AF-C) mode, AF-D also uses additional assist areas to help auto focus.
    NOTE:  AF-D is only compatible with select lenses. It is recommended you shoot images with AF-D if you have a compatible lens.
