When recording XAVC S 4K movies on a memory card inserted in the camera, the image may not be displayed on the external monitor or the camera’s monitor, depending on the settings for Proxy movie recording.
- To resolve this, set the Proxy Recording setting to the appropriate parameter according to usage.
- For some models, if you set Proxy Recording to Off and Record Setting to 24p, the image will be displayed on the screen of both the external monitor and the camera.
Note: The available file formats differ depending on the camera model. For details, refer to the camera Operating Instructions or Help Guide.
When File Format is set to XAVC S HD or AVCHD, and HDMI Info. Display is set to On:
During standby for movie recording
- Images and information are displayed.
- The monitor is turned off.
While recording movies
When File Format is set to XAVC S HD or AVCHD, and HDMI Info. Display is set to Off:
- Images are displayed, but information is not.
When File Format is set to XAVC S 4K, and the images are recorded to a memory card inserted in the camera
- Proxy Recording: Off
- Images are not displayed.
Information is displayed.
- Only for compatible models with Proxy Recording set to Off and Record Setting set to 24p
Note: Compatible models are the ILCE-7RM4, ILCE-7RM4A, DSC-RX100M7, ILCE-6600, ILCE-9M2, ZV-1, ZV-1F, ILCE-7C, and ZV-E10
- Proxy Recording: On
- Images and information are not displayed.
When File Format is set to XAVC S 4K, and 4K Output Sel. is set to HDMI Only:
During playback
When the camera is connected via HDMI, images are only displayed on the external monitor during playback regardless of the HDMI Info. Display setting or whether File Format is set to 4K or HD.
