Applicable Model
This information is for the following model(s):
  • ILCE-1
About This Download
Things To Keep in Mind Before Performing the Update
  • Updates should be installed in chronological order. When updating from Ver. 1.32 or earlier, you need to update to Ver. 2.01 first before proceeding with the Ver. 4.00 update.
  • The update software for this product will be provided in the memory card version.
  • You can download the software update using the Creators' App available in the App Store and Google Play.
Benefits and Improvements
  • Adapts the display layout of shooting information for both horizontal and vertical viewing
  • Adds the Spot: XL and Spot: XS options to the Spot section of the Focus Area menu
  • Adds the Custom 1, Custom 2, and Custom 3 options to the Custom section of the Focus Area menu
  • Adds the Tracking: Spot XL, Tracking: Spot XS, Tracking: Custom 1, Tracking: Custom 2, and Tracking: Custom 3 options to the Tracking section of the Focus Area menu
  • Allows simultaneous deletion and rating of images stored on both memory card slot 1 and slot 2
  • Allows the display of folder and file names during playback
  • Allows you to cancel the scheduled transfer of selected images during FTP transfer
  • Adds support for the following Transfer & Tagging settings:
    • A setting to automatically schedule FTP transfer of protected still images from FTP Import
    • A setting to automatically schedule FTP transfer of protected still images and videos from FTP Upload Preset
    • A setting to automatically protect still images transferred via FTP from FTP Upload Preset
      • The latest version of the Transfer & Tagging app is necessary.
      • The Transfer & Tagging setting may not be available in some countries or regions.
  • Supports the following Monitor & Control app functions:
    • Focus map display
    • IRIS operation bar display
      • The latest version of the Monitor & Control app is necessary.
      • The Monitor & Control app may not be available in some countries or regions.
  • Supports the Write Digital Signature function for movies as part of Sony’s Camera Authenticity Solution
    • The timing for the provision of licenses (paid) to customers other than certain media outlets is yet to be determined.
    • Services may not be available in some countries or regions. For more information, please visit the Authenticity Catalog Page.
  • Supports Scan and Tag, Photo Cropping, and Volume Photography Commands under the Volume Photography License
    • Installation of a paid license is required for use.
  • No longer supports the Security (IPsec) functionality. Please enable and use Access Authen. for enhanced protection and security
  • No longer supports WPA and WEP functionalities. You will no longer be able to select WPA or WEP when connecting to Wi-Fi. Please use the more secure WPA2 or WPA3 security setting moving forward
  • Fixes an issue where continuous shooting may not resume for 1 to 2 seconds after the end of a continuous shooting session
  • Fixes an issue where the multi-selector on the vertical grip may not function correctly
  • Improves the operational stability of the camera
Note: Please refer to the Help Guide for details on all updated functions.
Previous Benefits and Improvements
File Info
  • Name: BODYDATA.DAT
  • Version: 4.00
  • Size: 798 702 984 bytes
  • Release Date: 10-12-2025
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the System Software Version
Follow the instructions below to check the system software version:
    1. Select MenuSetupSetup OptionVersionBody.
    2. The system software version will be displayed.
    Notes:
    • If the system software version is Ver. 4.00, the update is not required.
    • When updating from Ver. 1.32 or earlier, you need to update to Ver. 2.01 first. Please update to Ver. 4.00 after updating to Ver. 2.01.
    • If you try to update this version without updating to Ver. 2.00 or Ver. 2.01 first, an error will occur and you will not be able to update the software.
    • If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and/or time to the correct values.
    Saving the System Software Data to a Memory Card
    IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
      1. Click the Download button.
      2. After reading the disclaimer, click Download.
      3. Save the file to your computer.
      4. Insert the formatted memory card into the computer.
      5. Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
      Notes:
      • Please format the memory card in advance using this camera.
      • Before formatting, copy the data to a computer or other device.
        • Once you format the memory card, all the data recorded on the memory card will be deleted and cannot be restored.
      • Please refer to the instruction manual of the camera for compatible memory cards.
      Other Hardware
      • Power source for the camera: Use a fully charged rechargeable battery pack (NP-FZ100).
        Note: The update can only be performed when the battery power level is 51% or more. We recommend you use a fully charged battery.
      • Detach the vertical grip from the camera before updating the system software.
      Updating the System Software Version
      Important Notice
      • Use a fully charged rechargeable battery pack (NP-FZ100).
      • Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
      • It may not be possible to update if the camera temperature is high. Please wait to update until after the temperature drops.
      Step 1: Update the System Software
      1. Insert the memory card that contains the saved system software data into slot 1 of the camera. Only slot 1 will recognize the system software data.
      2. Select MenuSetupSetup OptionVersionBody.
      3. Select Software Update.
      4. Select Execute on the system software update confirmation screen. The software version update will start.
        On-screen message:
        • Update? X.XX → Y.YY
          • X.XX: Current version number
          • Y.YY: Newest version number
        Notes:
        • Do not remove the battery or memory card during the update.
        • After confirming the details, you may click Execute.
        • Please scroll down the screen as necessary to view the full text.
      5. When the system software update starts, a black screen will be displayed and the access lamp will flash 1 time3 times5 times depending on the progress of the update. The update will take approximately 6 minutes to complete.
        Location of the Access lamp is on the bottom right of Rear side.
        Notes:
        • If the system software data copy is incorrect, the message “The target model for the update file is incorrect” will be displayed on the camera monitor.
        • If the access lamp repeats 5 long blinks (0.5-second cycle) and 6 short blinks (0.25-second cycle), or 7 long blinks (0.5-second cycle) and 7 short blinks (0.25-second cycle), it is possible you have not updated from Ver. 2.00 or later, or the system software may have been incorrectly copied to the memory card.
          • In this case, remove the battery and memory card from the camera, prepare another memory card, and then start over from the Saving the System Software Data to a Memory Card section of this article.
      6. When the update is complete, the camera will automatically restart. After restarting, press OK on the “Body update complete”.
      Step 2: Confirm the System Software Version of Your Camera
        The update was successful if screen shows Ver. 4.00.
