Article ID : 00059035 / Last Modified : 29/01/2026Print
    What is the difference between the LA-EA1, LA-EA2, LA-EA3, LA-EA4 and LA-EA5 lens mount adapters?
    IMPORTANT: Before using any mount adapter, please note:
     LA-EA5LA-EA4LA-EA3LA-EA2LA-EA1
    Features
    • Supports 35mm full-frame sensors
    • High-speed continuous shooting with AF/AE is available with supported cameras.
    • Built-in AF motor
    • Small cylindrical shape
    • Built-in AF sensor and AF motor using translucent mirror technology
    • Supports APS-C sensor
    Auto focus in Still Image ModeAF is available with all Sony A-mount lenses*1 in combination with a supported camera.
    AF is available with only SAM/SSM lenses when used with other cameras.
    AF is available*2 with all Sony A-mount lenses.*1AF is available with only SAM/SSM lenses.AF is available*2 with all Sony A-mount lenses.*1AF is available with only SAM/SSM lenses.
    Auto focus in Movie ModeAF operates when the shutter button is pressed halfway when using a lens noted in “Auto focus in Still Image Mode” in the line above.*2AF is available*2 with all Sony A-mount lenses.*1AF operates when the shutter button is pressed halfway when using a lens noted in “Auto focus in Still Image Mode” in the line above.*2AF is available*2 with all Sony A-mount lenses.*1AF operates when the shutter button is pressed halfway when using a lens noted in “Auto focus in Still Image Mode” in the line above.*2
    AF systemFocal plane phase-detection AF or Contrast AF depending on the camera used.Phase-detection AF (Sensor built into the mount adapter)Focal plane phase-detection AF or Contrast AF depending on the camera used.Phase-detection AF (Sensor built into the mount adapter)Focal plane phase-detection AF or Contrast AF depending on the camera used.
    Available AF ModeAF-S, AF-C, AF-A, DMF
    Eye AF is also available when using focal plane phase-detection AF.*3
    AF-S, AF-C, AF-A, DMF *4
    Eye AF is unavailable.
    • *1 STF lenses are manual focus only lenses, auto focus will not operate with any adapter.
    • *2 Auto focus may not function with certain camera models, defaulting to manual focus only. Check your camera's Help Guide for details.
    • *3 Eye AF may be unavailable when using the mount adapter, depending on the camera used.
    • *4 Differs depending on the combination of camera and lens used.
