Applicable Model
This information is for the following model(s):
  • ILCE-6700
  • ILCE-6700K
  • ILCE-6700L
  • ILCE-6700M
About This Download
What to Keep in Mind Before Performing the Update
  • You can download the software update using the Creators' App available in the App Store and Google Play.
Benefits and Improvements
  • Increases the maximum number of images that can be recorded in one folder to 9,999
  • Improves image quality when applying user LUTs
  • Displays the Wi-Fi signal strength when the Wi-Fi function is On
  • Allows notifications to be displayed when the latest software is available for your camera
  • You can now continue shooting while transferring captured photos and videos to a smartphone or tablet
    Note:
    • Ver. 2.9.0 or later of the Creators' App is necessary. This service may not be available in some countries or regions. For more information, please visit the Creators' Cloud support website.
  • Transfers to smartphones and tablets can now be resumed if they are interrupted
    Note:
  • You can now transfer only the data that hasn't yet been sent to your smartphone or tablet, or add videos to be transferred during the transfer process
    Note:
  • Allows you to upload camera images directly to the Creators' Cloud
    Notes:
    • Settings must be adjusted in the Creators' App in advance. For more information, please visit the Creators' App support website.
  • WPA and WEP functionalities are no longer supported. You will no longer be able to select WPA or WEP when connecting to Wi-Fi. Please use the more secure WPA2 or WPA3 security setting moving forward
  • Improves the operational stability of the camera
Note: Please refer to the Help Guide for details on all updated functions.
Previous Benefits and Improvements
File Info
  • Name: BODYDATA.DAT
  • Version: 2.00
  • Size: 1 024 017 848 bytes
  • Release Date: 10-06-2025
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the System Software Version
Follow the instructions below to check the system software version.
    1. Select MenuSetupSetup OptionVersion.
    2. The system software version will be displayed.
    Notes:
    • If the system software version is Ver. 2.00, the update is not required.
    • If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and/or time to the correct values.
    Saving the System Software Data to a Memory Card
    IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
    1. Click the Download button.
    2. After reading the disclaimer, click Download.
    3. Save the file to your computer.
    4. Insert the formatted memory card into the computer.
    5. Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
    Notes:
    • Please format the memory card in advance using this camera.
    • Before formatting, copy the data to a computer or other device.
      Once you format the memory card, all the data recorded on the memory card will be deleted and cannot be restored.
    • Please refer to the instruction manual of the camera for compatible memory cards.
    Other Hardware
    • Power source for the camera: Fully charged rechargeable battery pack (NP-FZ100).
      Note: The update can only be performed when the battery power level is above 51%. We recommend you use a fully charged battery.
    Updating the System Software Version
    Important Notice
    • Use a fully charged rechargeable battery pack (NP-FZ100).
    • Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
    • It may not be possible to update if the camera temperature is high. Please wait to update until after the temperature drops.
    Step 1: Update the System Software
    1. Insert the memory card that contains the saved system software data into slot of the camera.
    2. Select MenuSetupSetup OptionVersion.
    3. Select Software Update.
    4. Select Execute on the system software update confirmation screen. The software version update will start.
      On-screen message:
      • The Update? X.XX → Y.YY
        • X.XX: Current version number
        • Y.YY: Newest version number
      Notes:
      • Do not remove the battery or memory card during the update.
      • After confirming the details, you may click Execute.
      • Please scroll down the screen as necessary to view the full text.
    5. When the system software update starts, a black screen will appear and the access lamp will flash 1 time3 times5 times depending on the progress of the update. The update will take approximately 6 minutes to complete.
      The access lamp is located under the left side of the camera when the Rear side of the camera is facing you.
      Notes:
      • If the system software data copy is incorrect, the message The target model for the update file is incorrect will be displayed on the camera monitor.
      • If the access lamp repeats 5 long blinks (0.5-second cycle) and 6 short blinks (0.25-second cycle), or repeats 7 long blinks (0.5-second cycle) and 7 short blinks (0.25-second cycle), the system software may have been incorrectly copied to the memory card.
        • In this case, remove the battery and memory card from the camera, prepare another memory card, and then start over from the Saving the System Software Data to a Memory Card section of this article.
    6. When the update is completed, the camera will automatically restart. After restarting, when the Body update complete screen appears, press OK.
    Step 2: Confirm the System Software Version of Your Camera.
    1. Select MenuSetupSetup OptionVersionBody.
      The update was successful if the screen shows Ver. 2.00.
