Article ID : 00075429 / Last Modified : 16/10/2025Print
The camera battery doesn't charge when connected to a computer with a USB cable
    Before you start
    • Please check if your camera supports charging the battery while it is inserted and connected to a computer. You should be able to confirm this in the Help Guide of your camera.
    • Depending on your computer, USB charging may not be possible during Sleep mode. Make sure to turn off your computer's Sleep mode first.
    • Using a USB hub isn't guaranteed to work. Connect the cable directly to the computer's USB port.
    Check the connection
    1. Turn on your computer.
      • If you're using a notebook computer, plug it into a power outlet using the AC adapter.
    2. Turn off the camera and then connect the USB cable to the USB terminal.
      • The camera won't charge if it's turned on.
      • If your camera turns off automatically, wait for ten seconds before plugging it into the USB port.
    3. Connect the other end of the cable to a USB port on the computer.
    4. Make sure the charging light turns on.
      • If the charging light turns off right after charging starts, the battery may already be full. Check the battery level of your camera.
    5. If the camera doesn't charge, try using a different USB port or another computer.
