Does autofocus work in Continuous Shooting or Speed Priority Continuous focus modes?
When autofocus is set to AF-A or AF-C, you may be able to adjust focus in Continuous Shooting mode. However, restrictions may apply depending on the camera and lens. Read this article for more information.
Note: Before starting, update the camera, lens, or mount adapter to the latest version of the system software (firmware) available.
Availability of autofocus in continuous shooting (1)
| Autofocus Mode Setting | Fast Hybrid AF Using Compatible Lens | Fast Hybrid AF Using Non-Compatible Lens | Mount Adapter Using LA-EA1 | Mount Adapter Using LA-EA3, LA-EA5 | Mount Adapter Using LA-EA2, LA-EA4 | |
| ILCE-1 | AF-C | Yes *17 | Yes *2 | Yes *2 | Yes *17 | No |
| ILCE-1M2 | AF-C | Yes *17 | Yes *2 | Yes *2 | Yes *17 | No |
| ILCE-9 | AF-C | Yes *10 | Yes *2 | Yes *2 | Yes *14 | Yes *2 |
| ILCE-9M2 | AF-C | Yes *10 | Yes *2 | Yes *2 | Yes *14 | Yes *2 |
| ILCE-9M3 | AF-A or AF-C | Yes *18 | Yes *2 | Yes *2 | Yes *19 | No |
| ILCE-7RM2 | AF-A or AF-C | Yes *1 | Yes *2 | Yes *3 | Yes *3 | Yes *2 |
| ILCE-7RM3 | AF-A or AF-C | Yes *1 | Yes *2 | Yes *3 | Yes *3 | Yes *2 |
| ILCE-7RM3A | AF-A or AF-C | Yes *1 | Yes *2 | Yes *3 | Yes *3 | Yes *2 |
| ILCE-7RM4 | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *6 | Yes *2 |
| ILCE-7RM4A | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *6 | Yes *2 |
| ILCE-7RM5 | AF-A or AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *16 | No |
| ILCE-7RM6 | AF-A or AF-C | Yes *20 | Yes *2 | No | Yes *20 | No |
| ILCE-7SM3 | AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | No |
| ILCE-7 | AF-C | Yes *4 | Yes *5 | No | No | Yes *5 |
| ILCE-7M2 | AF-C | Yes *1 | Yes *2 | Yes *3 *8 | Yes *3 *8 | Yes *2 |
| ILCE-7M3 | AF-A or AF-C | Yes *1 | Yes *2 | Yes *3 | Yes *3 | Yes *2 |
| ILCE-7M4 | AF-A or AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *16 | No |
| ILCE-7M5 | AF-A or AF-C | Yes *20 | Yes *2 | No | Yes *20 | No |
| ILCE-7CR | AF-A or AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *16 | No |
| ILCE-7CM2 | AF-A or AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *16 | No |
| ILCE-7C | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | Yes *2 |
| ZV-E1 | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *9 | No |
| ILCE-5100 | AF-A or AF-C | Yes *6 | Yes *2 | No | No | Yes *2 |
| ILCE-6000 | AF-A or AF-C | Yes *6 | Yes *2 | No | No | Yes *2 |
| ILCE-6100 | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | Yes *2 |
| ILCE-6100A | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | Yes *2 |
| ILCE-6300 | AF-A or AF-C | Yes *9 | Yes *2 | Yes *3 | Yes *3 | Yes *2 |
| ILCE-6400 | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | Yes *2 |
| ILCE-6400A | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | Yes *2 |
| ILCE-6500 | AF-A or AF-C | Yes *9 | Yes *2 | Yes *3 | Yes *3 | Yes *2 |
| ILCE-6600 | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *6 | Yes *2 |
| ILCE-6700 | AF-A or AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *16 | No |
| ZV-E10 | AF-A or AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | Yes *2 |
| ZV-E10M2 | AF-A or AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *15 | Yes *2 |
| NEX-5R | AF-C | Yes *7 | Yes *5 | No | No | Yes *5 |
| NEX-5T | AF-C | Yes *7 | Yes *5 | No | No | Yes *5 |
| NEX-6 | AF-C | Yes *7 | Yes *5 | No | No | Yes *5 |
| ILME-FX2 | AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *2 | No |
| ILME-FX3 | AF-C | Yes *13 | Yes *2 | Yes *2 | Yes *2 | No |
| ILX-LR1 | AF-A or AF-C | Yes *15 | Yes *2 | Yes *2 | Yes *16 | No |
Availability of autofocus in continuous shooting (2)
| Autofocus Mode Setting | Contrast AF | Mount Adapter Using LA-EA1, LA-EA3, LA-EA5 | Mount Adapter Using LA-EA2, LA-EA4 | |
| ILCE-7R | AF-C | Yes *5 | No | Yes *5 |
| ILCE-7SM2 | AF-C | Yes *5 | No | Yes *5 |
| ILCE-7S | AF-C | Yes *5 | No | Yes *5 |
| ILCE-3000 | AF-C | Yes *5 | No | Yes *5 |
| ILCE-3500 | AF-C | Yes *5 | No | Yes *5 |
| ILCE-5000 | AF-C | Yes *5 | No | Yes *5 |
| NEX-3 | AF-C | Yes *5 | No | Yes *5 *12 |
| NEX-3N | AF-C | Yes *5 | No | Yes *5 |
| NEX-5 | AF-C | Yes *5 | No | Yes *5 *12 |
| NEX-7 | AF-C | Yes *5 | No | Yes *5 |
| NEX-C3 | AF-C | Yes *5 | No | Yes *5 *11 |
| NEX-F3 | AF-C | Yes *5 | No | Yes *5 |
Availability of autofocus in continuous shooting (3)
| Autofocus Mode Setting | Compatibility | |
| DSC-RX1RM3 | AF-A or AF-C | Yes *1 |
| DSC-RX10M4 | AF-A or AF-C | Yes *1 |
| DSC-RX100M5 | AF-A or AF-C | Yes *1 |
| DSC-RX100M5A | AF-A or AF-C | Yes *1 |
| DSC-RX100M6 | AF-A or AF-C | Yes *1 |
| DSC-RX100M7 | AF-A or AF-C | Yes *1 |
| DSC-RX100M7A | AF-A or AF-C | Yes *1 |
| ZV-1M2 | AF-A or AF-C | Yes *1 |
| ZV-1 | AF-A or AF-C | Yes *1 |
| ZV-1A | AF-A or AF-C | Yes *1 |
Notes
- *1 AF may not be tracked while in Continuous Shooting mode in the following cases:
- If the subject is outside the range of the phase-detection AF sensor.
- When shooting in a dark environment.
- When shooting with no subject contrast, such as blue skies or a white wall.
- If the aperture value is more than F8 or if, for the ILCE-7M3, the aperture value is larger than F11.
- *2 Only compatible with Continuous Shooting Lo.
- *3 Only compatible with Continuous Shooting Lo.
- Note: You need to set Phase-detection AF for the AF system in the custom menu.
- *4 AF may not be tracked in Speed Priority Continuous Shooting mode in the following cases:
- If the subject is outside the range of the Phase-detection AF sensor.
- If the aperture value is more than F8.
- *5 Only compatible with Continuous Shooting mode. (You will not be able to continue to focus in Speed Priority Continuous Shooting mode.)
- *6 AF may not track when shooting subjects with poor contrast, such as blue skies or a white wall, or in a dark environment. You will not be able to continue to focus with the Mid / Hi setting in the following cases. In these cases, select the Lo setting.
- If the aperture value is more than F11.
- When the system software of the LA-EA3 is Ver.01.
- *7 AF cannot be tracked in Speed Priority Continuous Shooting mode in the following cases:
- If the aperture value is more than F6.3.
- *8 Software Ver.2.0 or later is required.
- *9 AF may not track when shooting subjects with poor contrast, such as blue skies or a white wall, or in a dark environment. You will not be able to continue to focus with the Mid /Hi / Hi+ setting in the following cases. In these cases, select the Lo setting.
- *10 AF may not be tracked when shooting in a dark environment. You will not be able to continue to focus in the following cases:
- If the aperture value is more than F16.
- *11 Software Ver.02 or later is required.
- *12 Software Ver.05 or later is required.
- *13 The camera may not be able to maintain focus on a subject using AF during continuous shooting in the following situations:
- When the subject is outside of the Phase-detection AF sensor area.
- When shooting in dark surroundings.
- When the contrast of the subject is low, such as a blue sky or a white wall.
- When the aperture value is greater than F11.
- *14 AF may not track when shooting subjects with poor contrast, such as blue skies or a white wall, or in a dark environment. You will not be able to continue to focus with the Mid / Hi setting in the following cases. In these cases, select the Lo setting.
- When the F-value is greater than F16.
- *15 The camera may not be able to maintain focus on a subject using AF during continuous shooting in the following situations:
- When the aperture value is greater than F22, the focus is fixed at the position determined during the first shot, if continuous shooting is set to Continuous Shooting: Hi+ / Continuous Shooting: Hi / Continuous Shooting: Mid.
- *16 AF may not be tracked when shooting subjects with low contrast, such as blue skies or a white wall, or in a dark environment. You will not be able to continue to focus in Hi+ / Hi / Mid in the following cases. In this case, set to Lo.
- When the F-value is greater than F22.
- *17 AF may not be tracked when shooting subjects with low contrast, such as blue skies or a white wall, or in a dark environment. You will be able to continue to focus in only Lo (Shutter Type: Mechanical Shutter) in the following cases.
- *18 AF may not be tracked while in Continuous Shooting mode in the following cases:
- When Aperture Drive in AF is set to Standard or Silent Priority and the F-value is greater than F22.
- When Aperture Drive in AF is set to Focus Priority, the F-value is greater than F22, and the continuous shooting speed is 120 images/s or 60 images/s.
- *19 AF may not be tracked while in Continuous Shooting mode in the following cases:
- With continuous shooting set to Hi+ / Hi and Single-shot AF / DMF / Manual Focus selected, the first shot determines the focus. When the camera is set to Continuous AF, you can perform continuous shooting with AF tracking at a maximum speed of 10 images/s.
- *20 AF may not be tracked while in Continuous Shooting mode in the following cases:
- When the aperture value is greater than F22, the focus is fixed at the position determined during the first shot.
