Applicable Model
This information is for the following model(s):
  • ILCE-7M5
About This Download
What to Keep in Mind Before Performing the Update
  • You can download the software update using the Creators' App available in the App Store and Google Play.
Benefits and Improvements
  • Fixes an issue where noise may appear in the preview image embedded in RAW files captured with the RAW & HEIF setting
  • Fixes an issue where the camera may not power on after being turned off while the Connect while Power Off setting is enabled
    (under Network → Connect/Remote Shoot)
  • Improves compatibility with third-party CFexpress Type A memory cards
  • Improves the operational stability of the camera
File Info
  • Name: BODYDATA.DAT
  • Version: 1.01
  • Size: 332 873 264 bytes
  • Release Date: 12-02-2026
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
If you are updating from Ver. 1.00, please set both Cnct. while Power Off and Wi-Fi Connect to Off in advance. Then turn off the camera, remove and reattach the battery, and proceed with the update.
If you are updating from Ver. 1.00, please follow these steps before starting the update:
  1. Set the Cnct. while Power OFF setting to Off.
  2. Set the Wi-Fi Connect setting to Off.
  3. Turn off the camera.
  4. Remove the battery, then reinsert it.
You are now ready to perform the update.
Check the System Software Version
Follow the instructions below to check the system software version:
  1. Select MenuSetupSetup OptionVersion Body.
  2. The system software version will be displayed.
Notes:
  • If the system software version is Ver. 1.01, the update is not required.
  • If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and/or time to the correct values.
Saving the System Software Data to a Memory Card
IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
    1. Click the Download button.
    2. After reading the disclaimer, click Download.
    3. Save the file to your computer.
    4. Insert the formatted memory card into the computer.
    5. Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
    Notes:
    • Please format the memory card in advance using this camera.
    • Before formatting, copy the data to a computer or other device. Once you format the memory card, all the data recorded on it will be deleted and cannot be restored.
    • Please refer to the instruction manual of the camera for compatible memory cards.
    Other Hardware
    • Power source for the camera: Use a fully charged rechargeable battery pack (NP-FZ100).
      Note: The update can only be performed when the battery power level is 51% or more. We recommend you use a fully charged battery.
    • Detach the vertical grip from the camera before updating the system software .
    Updating the System Software Version
    Important Notice
    • Use a fully charged rechargeable battery pack (NP-FZ100).
    • Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
    • It may not be possible to update if the camera temperature is high. Please wait to update until after the temperature drops.
    Step 1: Update the System Software
    1. Insert the memory card that contains the saved system software data into slot 1 of the camera. Only slot 1 will recognize the system software data.
    2. Select MenuSetupSetup OptionVersionBody.
    3. Select Software Update.
    4. Select Execute on the system software update confirmation screen. The software version update will start.
      On-screen message:
      • Update? X.XX → Y.YY
        • X.XX: Current version number
        • Y.YY: Newest version number
      Notes:
      • Do not remove the battery or memory card during the update.
      • After confirming the details, you may click Execute.
      • Please scroll down the screen as necessary to view the full text.
    5. When the system software update starts, the elapsed time and progress rate appear, and the access lamp flashes 1 time3 times5 times as the update progresses. The update will take approximately 6 minutes to complete.
      Location of the Access lamp: It's on the bottom right of Rear side.
      Notes:
      • If the system software data copy is incorrect, the message “The target model for the update file is incorrect” will be displayed on the camera monitor.
      • If the access lamp repeats 5 long blinks (0.5-second cycle) and 6 short blinks (0.25-second cycle), or 7 long blinks (0.5-second cycle) and 7 short blinks (0.25-second cycle), the system software may have been incorrectly copied to the memory card.
        • In this case, remove the battery and memory card from the camera, prepare another memory card, and then start over from the Saving the System Software Data to a Memory Card section of this article.
    6. When the update is complete, the camera will automatically restart. After restarting, press OK on the “Body update complete” screen.
    Step 2: Confirm the System Software Version of Your Camera
    1. Select MenuSetupSetup OptionVersionBody.
      The update was successful if the screen shows Ver. 1.01.
