Applicable Model
This information is for the following model(s):
- ILCE-7SM3
About This Download
What to Keep in Mind Before Performing the Update
- Updates should be installed in chronological order: Ver. 2.15 or earlier→ Ver. 3.01→ Ver. 5.01. If you try to install Ver. 5.01without updating to Ver. 3.01, an error will occur and you will notbe able to update your camera.
- Some settings will notbe carried over to Ver. 5.01, even if they were previously saved using the Save/Loadsettings. When updating from Ver. 4 or earlier, we recommend writing down the following settings in advance:
- Network Streaming, Cloud Connection, and Access Authen.settings
- Switch Focus Areaand Send to Smartphonesettings registered to Custom Key
- Version, Touch Sensitivity, and Touch Panelsettings registered in My Menu
- This update is only available for memory cards. Windowsand macOSversions are notprovided.
- You can download the software update using the Creators' Appavailable in the App Storeand Google Play.
Benefits and Improvements
- Fixes an issue where part of the green frame indicating the AF (autofocus) status was not displayed when using the Expand Spotfeature
- Improves the operational stability of the camera
Previous Benefits and Improvements
File Info
- Name:BODYDATA.DAT
- Version:5.01
- Size:743 818 632 bytes
- Release Date:28-05-2026
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the System Software Version of Your Camera
Follow the instructions below to check the system software version of your camera:
- Select Menu→ Setup→ Setup Option→ Version → Body.
- The system software version will be displayed.
Update Sequence
- If the system software version is Ver. 5.01, the update is notrequired.
- If your camera is running Ver. 2.15 or earlier, you must first update to Ver. 3.01 before installing Ver. 5.01.
- Installing Ver. 5.01 directly without updating to Ver. 3.01 will result in an error, and the software update will fail.
- Required update path:
Ver. 2.15 or earlier→ Ver. 3.01 → Ver. 5.01. - If the Date/Timesetting screen appears when you turn on your camera, set the date and/or time correctly.
Saving the System Software Data to a Memory Card
IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
To save the system software data to a memory card:
- Click the Downloadbutton.
- After reading the disclaimer, click Download.
- Save the file to your computer.
- Insert the formatted memory card into the computer.
- Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
- Please use this camera to format the memory card in advance.
- Before formatting, copy the data to a computer or other device.
- After formatting, the data on the memory card will be permanently deleted and cannot be restored.
- Please refer to the instruction manual of the camera for compatible memory cards.
Power Requirements
- Power source: Use a fully charged rechargeable battery pack (NP-FZ100).
- The update can only be performed when the battery power level is 51% or higher. We recommend you use a fully charged battery.
Hardware Requirements
- Detach the vertical grip from the camera before updating the system software.
Updating the System Software Version
Important Notice
- Use a fully charged rechargeable battery pack (NP-FZ100).
- Do not remove the batteryduring the update. Doing so may cause the camera to become inoperable.
- It may notbe possible to update if the camera temperature is high. Please wait until the temperature drops before updating.
Step 1: Update the System Software of Your Camera
- Insert the memory card that contains the saved system software data into slot 1of the camera. Only slot 1will recognize the system software data.
- Select Menu→ Setup→ Setup Option→ Version→ Body.
- Select Software Update.
- Select Executeon the system software update confirmation screen. The software version update will start.
On-screen message:- Update? X.XX → Y.YY
- X.XX:Current version number
- Y.YY:Newest version number
- Do notremove the battery or memory card during the update.
- After confirming the details, click the Executebutton.
- Scroll down as needed to view the full text.
- When the system software update starts, a black screen will appear. The access lamp will flash 1 time→ 3 times→ 5 timesdepending on the progress. The update will take approximately 6 minutesto complete.
- When the update is complete, the camera will automatically restart. After restarting, press OKon the “Body update complete”screen.
Step 2: Confirm the System Software Version of Your Camera
The update was successful if the screen shows Ver. 5.01.
If the Update Fails
If the system software was not copied correctly to the memory card, the camera may display an error messageor signal an errorusing the access lamp.
What You May See:
- The message "The target model for the update file is incorrect" appears on the camera monitor.
- The access lamp blinksin one of the following patterns:
- 5 long blinks(0.5-second cycle) followed by 6 short blinks(0.25-second cycle)
- 7 long blinks(0.5-second cycle) followed by 7 short blinks(0.25-second cycle)
What This Means:
- The camera may not have been updated to Ver. 3.01 or later before attempting this update.
- The system software may have been copied incorrectly to the memory card.
What to Do:
- Remove the battery and memory card from the camera.
- Prepare another memory card.
- Start again from the Saving the System Software Data to a Memory Cardsection of this article.
