Article ID : 00375432 / Last Modified : 12/02/2026Print
    The battery will not finish charging inside the camera
    If you use an AC adapter with a low charging capacity (output current) to charge the battery inside the camera, the charging time will be significantly longer.
    To enable fast charging, connect a commercially available charging device that supports USB Power Delivery.
    Note: If your camera supports USB Power Delivery (USB PD), please use a USB PD compatible device with an output of 18W (9V/2A) or higher, and a USB Type-C® cable (USB-C to USB-C) that supports 3A or higher. This information should be available on the product, packaging or mentioned in the manual.
