Article ID : 00250423 / Last Modified : 26/03/2026Print
When connecting the source device via HDMI, the sound from the Home Theater System or Sound Bar is out of sync with the picture
    Depending on the sound source output from devices (Blu-ray Disc Player, set-top box (STB), game consoles), the sound may lag behind the picture, or the picture may lag behind the sound. If this is the case, select the solution which corresponds to the connected source device.
    When the source device is connected to the Home Theater System / Soundbar via HDMI
    If the Home Theater System or Soundbar has a SYNC (A/V sync) function, adjust the setting and see if the issue improves. For how to change the A/V sync setting, refer to the Home Theater System or Soundbar's manual.
    When the source device is connected to the TV via HDMI, or the audio source is output from the TV (TV broadcast, Netflix, Prime Video, Apple TV, etc.)
    • If your TV has a function that delays the image (A/V sync setting), try adjusting that setting. For details, refer to the TV's manual.
      Hints:
      • If your Home Theater System or Soundbar supports the Sony | BRAVIA Connect or Sony | Home Entertainment Connect app, you can adjust the delay using the following steps: SettingsSound SettingsAV Sync.
      • If your TV is a BRAVIA, change the A/V sync setting from Auto to Off or On. For details, refer to the TV's Operating Instructions or Help Guide.
      If your TV is BRAVIA, try the following settings on the TV:
      • Change A/V sync from Auto to Off or On
      • Change eARC mode to Auto
      • Change Pass through mode to Auto, or change Digital audio output to Prioritize pass through
      Hint: The menu item varies depending on the models. You can find the above settings on SettingsDisplay & SoundAudio Output, or SettingsDisplay & SoundAudio OutputAudio System Settings. For details, refer to the BRAVIA's manual.
      Examples of the settings:
      • Quick SettingsSettingsDisplay & SoundAudio outputPass through mode
      • Quick SettingsSettingsDisplay & SoundAudio output → Audio system settingsDigital audio output Prioritize pass through
    • If your Home Theater System or Soundbar is listed below, try the following settings:
      • For BRAVIA Theatre Quad (HT-A9M2) / BRAVIA Theatre Bar 9 (HT-A9000) / BRAVIA Theatre Bar 8 (HT-A8000)
        • On the Sony | BRAVIA Connect or Sony | Home Entertainment Connect app, select SettingsWireless Speaker SettingsWireless Playback Quality, and set it to Priority on Sound Quality
        • On the Sony | BRAVIA Connect app, select SettingsSound Settings, and disable DSEE Ultimate
      • For BRAVIA Theatre Bar 6 (HT-B600, HT-BD60) / BRAVIA Theatre System 6 (HT-S60) / BRAVIA Theatre Bar 5 (HT-B500, HT-BC50, HT-BD50) / HT-S2000
        • On the Sony | BRAVIA Connect or Sony | Home Entertainment Connect app, select SettingsSound Settings, and disable DSEE
      • For HT-A9 / HT-A7000 / HT-A5000 / HT-A3000
        • Press the HOME button on the remote control. Then, on the Home menu, select SetupAdvanced SettingsSpeaker SettingsWireless Speaker SettingsWireless Playback Quality, and set it to Priority on Sound Quality
        • Press the HOME button on the remote control. Then, on the Home menu, select SetupAdvanced SettingsAudio SettingsDSEE Extreme, and set it to Off
    • If the above workaround does not work well and your Home Theater System or Soundbar has an HDMI terminal, connect the source device directly to the Home Theater System or Soundbar using an HDMI cable. For details on the connection method, refer to the Home Theater System or Soundbar's Startup Guide or Help Guide.
      Note: If you want to connect many devices to the Home Theater System/Soundbar and the number of HDMI terminals is insufficient, connect the source device that delays the sound to the Home Theater System/Soundbar via HDMI first. If no more HDMI terminals are available on the Home Theater System or Soundbar, connect other devices to the HDMI terminals on the TV.
