Article ID : 00159369 / Last Modified : 16/01/2026Print
There is no audio from the Home theater, Amplifier or AVE receiver X9350D/X94C/X93C Series
    To output TV sound from the audio devices with Optical Digital Audio Out jacks or HDMI ARC jacks, set ClearAudio+ and Hi-Res Up-Scaling (DSEE HX) to Off with the following steps:
    NOTE:
    • X9350D/X94xxC/X93xxC series supports High-Resolution Audio but cannot output High-Resolution Audio from the Optical Digital Audio Out jacks or HDMI ARC jacks.
    • High-Resolution sound output will only work with the built-in speaker of Sony's Android TV.
    • Set ClearAudio+ to Off
      1. Press the HOME button on the remote.
      2. Select Settings.
      3. Select Sound in the TV category.
      4. Select Sound.
      5. Select ClearAudio+.
      6. Select Off.
    • Set Hi-Res Up-Scaling (DSEE HX) to Off
      2. Select Settings.
      4. Select Sound.
      5. Select Hi-Res Up-Scaling (DSEE HX).
      6. Select Off.
