Article ID : 00255773 / Last Modified : 10/04/2026Print
How to reset the soundbar or home theater system
    For how to reset the soundbar or home theater system, refer to the following:
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may change.
    • Not all models are sold in all countries or regions.
    HT-CT380 / HT-CT381 / HT-CT780
    Select another model
    1. Press on/standby to turn on the soundbar.
    2. Press MENU.
    3. Select SYSTEM by pressing the (upper) or (lower) button, then press ENTER.
    4. Select SYS.RST by pressing the (upper) or (lower) button, then press ENTER.
    5. When START appears on the display of the bar speaker, press ENTER. RESET appears on the display, and the settings will return to their initial status.
    6. When RESET disappears, disconnect the AC power cord (mains lead).
    7. Connect the AC power cord (mains lead), then press on/standby to turn on the soundbar.
    If the issue is still not resolved, refer to the product manual.
