Applicable Model
This information is for the following model(s):
- HT-G700
About this download
Benefits and Improvements
- Fixes an issue where there is no sound output when connecting to eARC
- Fixes an issue where the sound is output as ARC when connecting to eARC
Previous Benefits and Improvements
View previous benefits and improvementsSystem Requirements
Operating Systems
- Windows 11
- Windows 10
- Mac OS X
Notes:
- Operation is not guaranteed for all computers.
- The Operating System must be installed when the computer is shipped from the factory. Proper operation is not guaranteed for upgraded or multi-boot environments.
- Recommended environment operation is not guaranteed for all computers. In addition, we do not guarantee operation in products that you have installed on your own computer, upgraded products, multi-boot environments, and multi-monitor environments.
What you need
- USB storage device: Prepare a USB storage device formatted with FAT32.
Note: Do not use a USB storage device formatted other than FAT32. - USB type: USB2.0
- Capacity: over 256 MB
Note: Operation is not guaranteed for all USB storage devices, USB storage device conversion adapters, or USB Hubs.
File Info
File Name
- Firmware update version 1.107 or 2.127 for G700
File Version
- 1.107 or 2.127
Note: There are two software versions depending on the parts used.
File Size
- 3.60 MB (3 778 561 bytes)
Release Date
- 25-07-2023
Preparation
Check the firmware version
Your firmware may already be up to date, especially if you have a new Sound Bar. If the version number corresponds to the following, you do not need to perform the update.
- If the version is 1.xxx, 1.107 or higher
- If the version is 2.xxx, 2.127 or higher
If you're not sure, it's easy to check which version of firmware you have:
- Turn on this unit and make sure that it is in a normal start-up state.
- Connect a subwoofer to the unit.
Note: Please refer to the Operating Instructions for information on connecting a subwoofer to this unit. (A different software version will be displayed depending on whether the subwoofer is connected or not) - On the remote control, press MENU →
, select SYSTEM, and press ENTER.
repeatedly to select VERSION and press ENTER.
- The unit version information is displayed by scrolling.
- Check the software version. (If the software version is not the latest, a software update is required.) If the version number is 1.107 or 2.127 or higher, you already have the most recent firmware version.
Important Notice
- Read the instructions carefully, or you may damage your Sound Bar.
- Do not turn off the Sound Bar or disconnect it from the power while updating.
- Do not press any buttons, except the ones mentioned in the instructions.
- Do not unplug the power cable during the update. Doing so may cause damage and require repairs.
- Do not perform any operation until the update is complete.
The software is updated using a USB storage device. For details, please see the following procedure.
Note: Do not remove the power cable during the update. Doing so may cause damage to your unit, which may then require repairs.
Download & Install
If your computer can be connected to the Internet and to a USB storage device, you can use the computer to perform the update according to the steps below.
Step 1: Use the computer to transfer the updated software file to the USB storage device
- Click the Download button, read and agree to the terms and conditions, then click the Download button. The download will start.
- Save the file on the computer desktop or any location without changing the file name.
- Find the file on your computer, right-click it, and click Properties. If the size is 3.60 MB ( 3 778 561 bytes) then the download is completed successfully.
Note: If the size is other than the 3.60 MB ( 3 778 561 bytes), the download may have failed. Delete the file from the USB drive and download it again. - Double-click the downloaded file and select Extract all, and then select Extract without changing the folder name.
- When the extract is completed, a G700_Update folder will be created. Make sure that the FW_SB1.BIN, FW_SB1N.BIN file exists in that folder.
- Insert the USB storage device into the USB port of your computer.
- Drag and drop the downloaded FW_SB1.BIN, FW_SB1N.BIN file directly to the root of the USB storage device.
Note: If you do not save the FW_SB1.BIN, FW_SB1N.BIN file to the root of the USB storage device without any other files, the update may fail. - Confirm that the FW_SB1.BIN, FW_SB1N.BIN file exists in the root of the USB storage device. Once confirmed, transferring of the update file is completed and you can proceed to Step 2: Update the software of this unit.
- Connect the Sound Bar power cable.
- On the Sound Bar or remote control, push the
(Power) and wait until the panel display indicates the previous input.
- Check whether a Subwoofer is connected.
Note: If a Subwoofer is not connected, connect it. If needed, refer to the Operating Instructions about how to connect Subwoofer. - Insert the USB storage device containing the software update into the Sound Bar.
, select UPDATE and press ENTER.
- Select START and then press the ENTER button.
- The update process will start and the panel display will appear:
Notes:- Do not unplug the power cable during the update. Doing so may cause damage and require repairs.
- When DONE is displayed, the Sound Bar will restart automatically, and the update process is completed.
Note: The time needed to complete the update is about 3-10 minutes. - Be sure to check that the software version has been updated to the latest version by referring to the procedure Check the firmware version. If the correct version is not displayed, please check the version again after performing Initialize once. If you perform Initialize, the Bluetooth pairing information will also be deleted, so please perform pairing again. Depending on the connected device, it may be necessary to delete the Bluetooth device information on the connected device side and then re-pair. Also, the connection with the Subwoofer may be disconnected. In that case, check the contents of Connecting the Subwoofer manually in the instruction manual, and then connect.
Initialization method
- Press MENU. SPEAKER appears in the front panel display.
- Press
to select RESET, then press ENTER.
- Press
to select ALL RESET, then press ENTER.
- Press
to select START, then press ENTER. All the settings return to their initial status.
Note: If You Cannot Perform Resetting Using the Setting Menu, press and hold (Power) and - (volume) on the bar speaker for more than 5 seconds. The settings return to their initial status. Please check the instruction manual for details.
