Article ID : 00262058 / Last Modified : 20/01/2026Print
    The Wireless Speaker turns off automatically (SRS-RA Series)
    The wireless speaker will turn off automatically after 15 minutes if the audio input level of the connected device is very low or the audio playback stops.
    To prevent the speaker from turning off, set the Auto Standby function to OFF using the following steps.
    How to set the Auto Standby function to OFF
    SRS-RA5000
    Touch and hold the (Input) button and the (Volume +) button for more than 4 seconds.
    SRS-RA3000
    Touch and hold the Sound Mode)button and the AUDIO IN)button for more than 4 seconds.
    How do I know if the Auto Standby function is set to OFF or ON?
    When the Auto Standby setting is changed, the Power indicator flashes as follows:
    • When the Auto Standby function to OFF, the Power indicator on your speaker flashes three times in green.
    • When the Auto Standby function is set to ON, the Power indicator flashes twice in green.
    Two side-by-side images showing the location of the Volume + button, the Input button and the Power indicator flashing in green on the SRS-RA5000 speaker.
    NOTES:
    • The image above illustrates the SRS-RA5000 wireless speaker.
    • You can also use the Sony | Music Center app to set the Auto Standby function to OFF or ON. To download the app, visit the Google Play Store for Android devices or the Apple App Store for iOS devices.
