Article ID : 00365879 / Last Modified : 02/09/2025Print
    I'm unable to connect my TV and BRAVIA Theatre U neckband speaker
    Before you connect
    Make sure your TV supports the A2DP Bluetooth profiles for music playback. If so, you can connect the BRAVIA Theatre U (HT-AN7) to your TV via a Bluetooth connection and listen to the TV audio on the neckband speaker.
    Hint: If you use a BRAVIA TV, refer to the following article for details: Can I use Bluetooth audio devices with my Google TV™ or Android TV™?.
    How to pair and connect your TV and BRAVIA Theatre U
    Hint: For more details on Bluetooth pairing and connection, refer to the Help Guide.
    How to pair with your TV via Bluetooth
    * For the first time after purchase
    While the neckband speaker is powered off, press and hold the (power) / (BLUETOOTH) button for about 2 seconds until you hear a notification sound. The power turns on and the neckband speaker enters pairing mode. The (power) / (BLUETOOTH) indicator flashes twice in blue.
    * Do this procedure if your neckband speaker has been initialised (pairing information has been erased).
    How to pair additional TVs (if the neckband speaker has pairing information for other devices)
    While the power is off, press and hold the (power) / (BLUETOOTH) button for about 5 seconds until you hear a notification sound and the voice guidance says "Pairing". The neckband speaker enters pairing mode, and the (power) / (BLUETOOTH) indicator flashes twice in blue.
    Note: When you press and hold the (power) / (BLUETOOTH) button for about 2 seconds, you will hear a notification sound. Continue pressing the button to complete the pairing.
    How to connect to your TV via Bluetooth
    After pairing your devices, operate the TV to connect the neckband speaker via a Bluetooth connection.
    When the Bluetooth connection is complete, you will hear a notification sound from the neckband speaker, and the (power) / (BLUETOOTH) indicator flashes in blue.
    Note: For operating instructions, refer to your TV manual.
