Article ID : 00247590 / Last Modified : 28/01/2021Print
How to change table top stand height and position after set up
    Before you start
    • To see what TV stand options are available for the A8/A8x, XH95 and XH90/92 series, visit the article: Can I adjust the stand of my Sony Android TV?
    • The steps in the guide below require three people or more.
    • Make sure an adequate number of people is used to safely support the TV.
    • When you lift one side of your TV, make sure the opposite side doesn't drop to the floor.
    A8, XH95 (55, 65, 75), XH90 - XH91 - XH92 series TV
    1. Remove the stand from the TV.
      Removing the stand from the TV
    2. Support the bottom of your TV with a suitable material such as a stack of newspapers or magazines. The illustration shows the approximate size (width, height, and depth) of the recommended support material.
      The appropriate material size to put under the TV. A: Width, B: Height, C: Depth
      TV SeriesUnits are in inches
      [A] Width[B] Height[C] Depth
      A8H16-24Approx. 88 or more
      XH950 (55, 65, 75)16-24Approx. 108 or more
    3. Reattach the stand to your TV in the new position.
    ZH8 series TV
      removing the bolts
      Z8H16-24Approx. 18 or more
    1. Reattach the stand to your TV in the new position.
      • The image below is an example. For more information, refer to the Setup Guide included with your TV.
        wide stand
        narrow stand
