Article ID : 00230499 / Last Modified : 19/01/2026Print
    What is the battery level of my headphones' charging case?
    There are two ways to check the remaining battery level of the charging case:
    1. Check the remaining charge on the Sony | Headphones Connect app
      • For WF-1000XM3:
        Firmware version 2.0.2 or later is required.
    2. Check the remaining charge using the charging case indicator
      • For WF-1000XM5 WF-1000XM4 LinkBuds S (WF-LS900N) / LinkBuds (WF-L900) / LinkBuds UC (WF-L900UC) / WF-C700N:
        Check the status of the indicator while the earbuds are NOT in the charging case.
        Image showing the headphones removed from the charging case and the charging case indicator lighting patterns A and B
        Note: You cannot check the remaining charge of the case while it is recharging.
        • If the indicator on the charging case lights up in green (A):
          • The remaining battery charge is between 31% and 100%.
          • You can charge the earbuds normally using the charging case.
        • If the indicator lights up in orange (B):
          • The remaining battery charge is between 1% and 30%.
          • This means the remaining charge of the case is less than what you need to charge the earbuds fully.
          • We recommend charging the case.
        • If the indicator does not light up, or it turns off immediately:
          • The remaining charge of the charging case is less than 1%.
          • The case should be recharged.
      • For WF-1000XM3 WF-SP800N WF-XB700 WF-C500 WF-H800:
        Check the status of the indicator while the earbuds are in the charging case.
        • If the indicator on the charging case lights up in red:
          • The remaining battery charge is between 30% and 100%.
        • If the indicator lights up in red, but it flashes for about 15 seconds when closing the charging case:
          • The remaining battery charge is between 5% and 30%.
          • The remaining charge of the case is less than 5%.
