- Select the situation when noise is heard:
- Noise is heard when the headphones are exposed to wind
To reduce the wind noise, turn Off the Noise Canceling or Ambient Sound Control. Go to step 6.- Noise is heard while walking or running
When the Noise Canceling or Ambient Sound Control is On, the vibration of walking or running may be transmitted from your body and cause noise. To avoid this, turn Off the Noise Canceling or Ambient Sound Control. Go to step 6.- A rustling noise is heard when I move my body or head
The headphones' microphone and your ear may be in contact with each other. Check the way the headphones are worn. Go to step 3.- White noise (a small hissing noise or continuous static sound) is heard
- When the Noise Canceling function is ON
To avoid white noise, turn off the Noise Canceling function.
Note: If the white noise is heard during a phone call, refer to The noise canceling function does not work or white noise is heard during a call on the headphones. article. Go to step 6. - When the Ambient Sound Mode function is ON
The noise may be heard depending on the value of the Ambient Sound Mode. Change the value on the Sony | Sound Connect app. For details, refer to the Help Guide.
- Noise is heard when I push the headphones into my ears, or when I tap the touch sensor strongly
This temporary noise can happen because of the Noise Canceling or Ambient Sound Control function and air-tightness of the headphones. This is normal, and not a malfunction.- An echo is heard when I cover the headphones or built-in microphone with my hand
An echo in this situation is normal and not a malfunction.- Noise is heard when the surrounding ambient noise is loud, such as when I am in a station or near a construction site.
When the Ambient Sound Control is On, the surrounding noises can be easily heard. Turn on the Noise Canceling function, or turn off the Ambient Sound Control function.- Noise is heard while talking on the phone
Go to step 2.- None of the conditions listed
If you hear your heartbeat or breathing, or if noise occurs when you change your posture such as moving your neck, this is normal and not a malfunction.
For other noises, go to step 6.
- If noise is heard during a phone call, select the appropriate situation:
- Fit the headphones to your ears firmly.
If the earbuds are not worn properly, do not fit your ears, or the air-tightness is insufficient, the phone call quality may decrease. To maintain quality, consider these factors:
- Make sure that headphones are worn properly
- Select the earbuds that best fit your ears. Measure the air-tightness of the earbud tips and find the optimal size of earbud tips using the Sony | Sound Connect app
- Make sure that the headphones' microphone and your ear are not in contact with each other.
- Try speaking louder.
- The issue is resolved
- The noise reduction function may have been the cause. When you speak quietly, the headphones may detect your voice as noise.
- The issue is not resolved
- Go to step 5.
- Use the headphones in a quieter place.
- The ambient sound may have been the cause.
- Go to step 7.
Turn off the Adaptive Sound Control function.
When the Adaptive Sound Control is set to On, the headphones detect your action (running, walking, etc.) and automatically switches the settings of the Noise Canceling function to Ambient Sound Control. To make maximum use of the Noise Canceling function, follow these steps to set the Adaptive Sound Control to off, and adjust the Noise Canceling or Ambient Sound Control manually.
Note: If the Adaptive Sound Control is set to On, the Noise Canceling is adjusted and Adaptive Sound Control is activated according to your action.- Turn off the Adaptive Sound Control.
- Connect the headphones and smartphone via Bluetooth, and then launch the Sony | Sound Connect app.
- In the My Device tab, check the Adaptive Sound Control status. If the status shows other than Off (Staying, Walking, etc.), select
right arrow on the right side of the Adaptive Sound Control menu.
- Select Noise Canceling to turn the setting On.
- The headphones settings were the cause of the issue.
- Go to step 7.
- Try the following procedure:
- Set the headphones in the charging case, close the lid, wait for about 10 seconds, and then wear the headphones again.
- Restart the connected device.
- The issue may have been caused by a temporary malfunction of the headphones.
- Go to the next troubleshooting step.
Reset the headphones.
Refer to the Help Guide or view the How to reset video:
Initialize the headphones.
Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Refer to the Help Guide or view the How to initialize video:
- The headphones may be malfunctioning, and service may be required.
Follow these steps to troubleshoot unwanted noise:
