This may occur when recording under fluorescent lamps, sodium lamps, or mercury lamps. Adjusting the shutter speed may reduce or minimize this issue.
- Set the shutter speed to improve the flicker phenomenon according to the region you are using the camera.
- If you use LED lights other than for movies, there is a case where horizontal stripes appear in the image. To prevent this phenomenon, use the LED light exclusive for movies.
NOTE: Not all camcorders or cameras have the capability of manually changing the shutter speed. Refer to the operating instructions supplied with the camcorder to check for available shutter speed options.
