Article ID : 00247634 / Last Modified : 13/01/2026Print
Sound from the subwoofer is too low
    Why can I barely hear the Subwoofer?
    Since a Subwoofer is designed to play bass sounds, when you play an audio source with fewer low frequencies, the sound from the Subwoofer can be harder to hear. Try playing a film with a varied audio source to check whether the Subwoofer's bass sound is being output correctly.
    Is the Subwoofer connected and turned on?
    Before you begin, make sure the Subwoofer is properly connected to the Soundbar and that the Subwoofer's indicator lights up.
    Follow these steps to troubleshoot the low-volume issue
    1. On the remote control, press the (plus) button of the SW (subwoofer volume) to turn up the subwoofer volume.
      Note: The button name varies depending on the model (subwoofer volumeBASS, etc.).
    2. If Night mode is set to ON, set it to OFF.
      Note: For details regarding Night mode, refer to the product manual.
    3. For HT-S2000, HT-A7000, HT-A5000, and HT-A3000 models, check the following settings:
      • HT-S2000
        1. Using the Sony | BRAVIA Connect or Home Entertainment Connect  app, select Settings → Sound Settings.
        2. Select Speaker position and volume level settings → Volume level, and then adjust the Subwoofer volume level.
      • HT-A7000 / HT-A5000 / HT-A3000: Make sure the Sound Field Optimization is complete:
        1. On the remote control, press the HOME button.
        2. Select Setup.
        3. Select Advanced Settings.
        4. Select Speaker Settings.
        5. Select Sound Field Optimisation and follow the on-screen instructions.
          Note:  For details, refer to the Help Guide.
    Play the test tone or built-in Demo music
    Try to play the test tone or built-in Demo music to verify if any sound is coming out of the subwoofer:
    Related article
    If the issue is unresolved, refer to the no sound coming from the Subwoofer article.
