There is no sound or the sound from the Rear speaker is too low
Before you start troubleshooting, keep in mind that the rear speaker plays surround sound as part of the multi-channel sound or is virtually processed from the 2-channel sound. Because of the characteristics of the rear speaker, the sound may be low depending on the playback source.
Follow these steps to troubleshoot this issue:
Note: For details on each setting, refer to the product manual or Help Guide. Manuals are posted on your model support page.
- On the Soundbar remote control, press the REAR (rear speaker volume) + button to turn up the volume.
Note: This button works only when the optional rear speaker is connected to the Soundbar. - If Night mode is set to ON, set it to OFF.
- Make sure the Sound Field Optimization is complete:
- For BRAVIA Theatre Quad (HT-A9M2), BRAVIA Theatre Bar 9 (HT-A9000), BRAVIA Theatre Bar 8 (HT-A8000):
- In the Sony | BRAVIA Connect app, select your model in My Devices.
- Select Settings.
- Select Sound Settings.
- Select Sound Field Optimization, and follow the on-screen instructions.
- For other models:
- On the remote control, press the HOME button.
- Select Setup.
- Select Advanced Settings.
- Select Speaker Settings.
- Play the Test Tone or sample music:
- Use the Test Tone function:
- For BRAVIA Theatre Bar 9 (HT-A9000), BRAVIA Theatre Bar 8 (HT-A8000):
- Select Settings.
- Select Sound Output Check.
- Select Test Tone, and tap Play.
Note: Tap Stop to stop the Test Tone.
- For HT-S2000:
- Select Settings.
- Select Speaker positioning and volume settings, and play the Test Tone.
- For other models:
- Select Setup.
- Select Manual Speaker Settings.
- Select Test Tone, and then select On.
Note: Select Off to stop the Test Tone.
- Play the sample music following the corresponding steps below:
- Select Settings.
- Select Demo Sound, and tap Play the demo.
Note: Tap Stop the demo to stop the sample music.
- For other models:
- Press and hold the
input select button on the bar speaker for more than 5 seconds to start playing the Dolby ATMOS sample music.
MUSIC SERVICE button on the bar speaker for more than 5 seconds to start playing the 360 Spatial Sound Mapping sample music.
- Depending on the SOUND FIELD and sound source settings combination, some speakers may not output sound. By pressing IMMERSIVE AE or SOUND FIELD to turn on the surround effect, the speaker system up-mixes audio signals, and sound is output from all speakers. Notes:
- BRAVIA Theatre Bar 9 (HT-A9000)/BRAVIA Theatre Bar 8 (HT-A8000)/HT-S2000: In the Sony | BRAVIA Connect app, select your model in My Devices, and set Sound Field to ON.
- For HT-A7000: On the remote control, press the IMMERSIVE AE button, and select Immersive Audio Enhancement: On.
- For HT-A5000, HT-A3000: On the remote control, press the SOUND FIELD button, and select Sound Field: Effect On or SF.ON.
- For details, refer to the Help Guide. Manuals are posted on your model support page.
- Depending on the source, such as Dolby Atmos, some settings are always set to ON and cannot be changed.
